i am having a problem with my wifi bluetooth connections after the os update
(Topic created on: 01-26-2025 03:47 PM)
Captain-HIGH
i am having a problem with my wifi bluetooth connections after the os update..????i want a solution for the problem
2 Comments
Munatsi399
Try diagnosing with members, and see if it doesn't provide a solution, should those be faulty
And also try , network resetting, if the error persists factory reset your device (backup your data 1st)
