01-13-2025 02:44 PM in
Galaxy A- Mark as New
01-13-2025 03:10 PM in
Galaxy A1 Enable Power saver
2 Enable performance mode light
3 Enable adaptive brightness
4 Disable AOD
5 Enable extra dim
6 Change display to natural
7 Record videos in FHD
8 Restrict gaming to HD or FHD and slower frame rate
9 Switch to dark mode
10 Disable near by device scanning
11 Disable WiFi scanning
12 If 5G is unavailable change network to LTE/3G/2G
13 Allow the battery to drain completely and recharge,say once a month.
14 Enable auto restart
15 Run device care
16 Disable apps running in back ground.
17 Uninstall bloat ware that came with your phone,eg. Spotify,LinkedIn etc.
You can mix match the steps above and arrive at a usage based on your needs.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
01-13-2025 03:16 PM in
01-13-2025 03:20 PM (Last edited 01-13-2025 03:26 PM ) in
Galaxy AIf this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
01-13-2025 05:08 PM in
01-14-2025 08:59 AM (Last edited 01-14-2025 11:13 AM ) in
Galaxy ADear Samsung Member,
Kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
