Resolved! Solved
Ultra and Extreme FPS option not in BGMI on A53 5G
(Topic created on: 03-31-2022 09:37 AM)
Karthik12334
Bought the brand new A53 5G. It doesn't have extreme and Ultra FPS options in BGMI. Even A50 have it. What might be the problem?
2 Solutions
tapas2580
A53 has a new processor exynos 1280 it will take time to optimize the game for that processor by the developers
Since A53 has a new processor, it will take time for apps to be optimized for it
If you find this helpful kindly click on the three dots and click accept as solution
38 Comments
Not applicable
Soc is the problem itself. You should have not purchase the device before checking in depth reviews.
Karthik12334
Thanks for making me feel bad about buying this phone 😊
Btw I am more than happy with this phone
vivek1989
No but still its good phone bro dont listen those **bleep** in the cmmnt section
Karthik12334
Yes😊
tapas2580
Karthik12334
So it have to be done at samsung's end?
tapas2580
Wait for update
tapas2580
Even exynos 9611 support smoth +extreme
Karthik12334
Yeah i know. Will wait for the update
