Sound problem in a51
(Topic created on: 06-27-2022 03:58 PM)
chintu1610
When the problems of sound in recovered in A51 it's a soft ware problem the public is so disappointed from the samsung the sound is not coming from the device a51 after the update please give a new update and clear the bug fixes I request you give a new update immediately
cs_member8
Dear Samsung member,
A: Disconnect all accessories:
1. Disconnect anything plugged into the headphone jack like, selfie stick, headphone, Bluetooth, etc.
2. Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device. (If any)
B: If the issue does not resolve then check device volume settings, please follows the below steps:
Settings >> Tap on Sound & vibration >> Tap on Volume >> Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
C: If issue not resolved then Check mute all sound option, please follow the below steps:
Settings >> Tap on Accessibility >> Tap on Hearing enhancements >> Disable Mute all sounds (if enabled).
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
