Samsung a14 5g heating issuue , and battery drain alot
(Topic created on: 04-12-2024 10:52 AM)
sonu36437
I owe galaxy a14 5g this was my worse decision to  buy a14 . It heats up alot for me heating doesn't makes the phone bad the worse part is that when it heats up it switch from 5g network to 4g this makes me feel bad and needs to be cooled down to use 5g network
3 Comments
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
cs_member8
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issues by given links.
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
Galaxy device battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
skm1hhdh
Beginner Level 4
I think it's my worst decision to buy Samsung galaxy a14 I'm frustrated with it's heating problem. It's totally disappointed
