Resolved! Solved
Samsung Galaxy a50s Battery drain issue
(Topic created on: 07-29-2020 10:23 AM)
MandarS23
I am facing this problem last  2 month's , i am   charging upto 80% but still i am facing this problem.  Please @Samsung kindly look this into the matter. Thank you
Malkits
same problem my Samsung Galaxy a50s battery drain faster
28 Comments
Malkits
MandarS23
I think we will soon get software update after Samsung a50.
Chuksa macoll
Remove dark mode and apply light mode
I don't know why but it extends its battery life after the update
MandarS23
yess but what to do ?
AnmolRaj
you should wait for an OTA Update and that should fix that.
MandarS23
hope so ...
Ehsank
do these settings bro then wait for the next update
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Ehsank
some more important thing to save battery
1.dont charge 100 on daily basis
and dont put on charge untill your battery goes to 20-30%
and sometimes clean ur charge port with any soft brushes
MandarS23
but still facing this problem
