Samsung A52 Battery drain issue
(Topic created on: 05-05-2022 06:20 PM)
AshokMandal
After new update automatically battery drain
Automatic battery drain start from 60%
5 Comments
pran2002
Yeah it also happened with my device but now I have no such problem and my backup is
Good
AshokMandal
How to solve
pran2002
Factory reset ur phone
AshokMandal
Uff!!😔
cs_member8
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
