Samsung A52 4g battery drain issues
(Topic created on: 02-12-2024 01:40 PM)
BoseChe
Hi guys,
 Did anybody facing battery drain issue in A52 4g?
I am facing this issue past few days. Nowadays I use to carry charger daily. By 3PM battery came to 30% for normal usage. Anybody suggest wat maybe the problem
7 Comments
Just wait ️ bro. You get will soon update.
Will be fixed after update.
BoseChe
Getting update only the question mark here. Whether we will get it r not. We should receive an update on December itself as samsung confirmed it. Will see.
Spidy3000
This Samsung a52 4g is now in Samsung quarterly update row. So Samsung A52 4G will get updates on every 3 months. So , Android 14 will come in March 2024 as last update was in December.
cs_member10
Dear Samsung Member,
We want to inform you about the Samsung Members app (Battery Status (Battery life + Battery Capacity).
You can check the "Battery Status (Battery life + Battery Capacity)" test using the Samsung Members app.
Battery life depends on how the battery is used. Note that different devices have different battery life. The expected battery life for your model can be found in the manual.
We would like to inform you about the standard charging procedure (charge in one go instead of charging many times as it affects the life span of the battery and battery performance).
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level.
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps.
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still occurs, please visit the service center for a physical device inspection. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Akjmar
Hii sir
Akjmar
सर मेरा सैमसंग गैलेkshi 3 साल पुराना है battery हेल्थ नॉर्मल है फिर भी batery ऑटो drain हो रहा है कोई बैकग्राउंड app रनिंग नहीं कर रहा है फिर भी batery drain हो रहा है क्यों
