Problem on A50,Help me😊
(Topic created on: 03-13-2020 04:46 PM)
SRBAJROLIYA
I can't find latest camera photos on other app.
Like I am changing WhatsApp dp I can't find recently camera photo.
This issue also happens on other app also camscaner, insta and etc.
Screenshot and edited camera photo showing but original not.
Why?
8 Comments
Devv_007
Hello,where are photos stored internal or sd card?are you able to access them from inbuilt gallery?
SRBAJROLIYA
internal
SRBAJROLIYA
photos are showing in gallery but problem are in other app.
Devv_007
Have you given permission of storage to specific app?if not then check from settings>Apps>Select app which has issue>Permissions>Storage(turn it on) and check the issue.
SRBAJROLIYA
Devv_007
In this situation you can try to clear cache of the app which has issue.Or try to move those photos from Camera folder to another.
Also try this- move all Camera photos to another temporary folder and delete the Camera folder from internal storage>DCIM>Camera.And then re-create a Camera foder and move photos from temp folder to Camera folder and then check issue.Hoping that this may work.
SRBAJROLIYA
yes of course, permission are on.
problem are only for recent camera photo other photos like screenshot and downloaded photos are showing.
Hi there,
Please perform the following steps to resolve the issue:
1- Settings > apps > tap on 3 dots (Upper right corner) > reset app preferences.
2- Settings > apps > tap on 3 dots > show system apps > gallery/camera app > storage> clear cache.
3- Settings > apps > Whats app/Instagram/cam-scanner > permission > camera > enable
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > click on “+“icon > send feedback > error report/ask questions).
Regards,
Team Samsung Members
