Resolved! Solved
Power Mode Problem On Samsung A50
(Topic created on: 07-23-2020 10:48 PM)
imran5577
Before Charging my phone power mode set on Medium Power Mode and Adaptive power saving enable but after charging atumatically my power mode turn into optimised mode.So whats the problem?
Not applicable
it's like that only if you switched on adaptive power saving.....see that phenomena worked on the basis of power consumption....when your device is fully charged then adaptive power saving option automatically understand that your device have much battery percentage thatswhy it turns off and reset your device as optimised mode which is recommended....and when your device battery getting lower by using apps or games then this adaptive mood helps to consume less battery thatswhy it's switched to medium power saving option.....now if you turn adaptive power saving mode off then the battery will remain that mood which you have seted for 🙂
10 Comments
RedIndianRobin
Disable "Adaptive power saving"
imran5577
Why both are not working at the same time?
Abdul_Rahman
Diable Adaptive power saving and keep your device in optimised mode only.Your battery will be drain slowly
imran5577
Which one is better ? Optimised or Medium power mode?
Abdul_Rahman
optimized is better than medium.
imran5577
Thanks for your advice☺
Turn off adaptive brightness and use optimized mode..it all depends on your usage..
Not applicable
imran5577
I am fully satisfied.Thanks Buddy☺
