Please Help Lock Screen Problem
(Topic created on: 11-06-2023 08:44 PM)
Not applicable
When the fingerprint lock is turned on and when the brightness is low, there are some wiered patches.
But when I turn off the fingerprint lock then its normal. Facing this issue with every wallpaper.
Factor reset done. Visited to the service centre but facing the same issue.
6 Comments
biswaroop
Apna je hard reset Koro to wipe data
Not applicable
Same issue. Display problem . Bad display.
Abz_
I have the same problem
SinghRajenM
I also have the same issue.
Samsung doesn't care about it.
Rohan8865
I also have same issue. Even videos have patchy issue bcz of display
cs_member10
Dear Samsung Member,
As per your concern, you have already visited the service center we would request you to kindly share the job sheet number on the Samsung Members Application (Open Samsung Members Application > Support> Ask question > Type your query > Send). So it will be helpful for us to resolve your issue.
