Hanging problem after pie update. Also problem in navigation.
(Topic created on: 03-31-2019 08:37 AM)
ANANDURPILLAI
I have A8+(2018). I got pie update then after my
 like opening application. Connecting calls. Camera quality etc.
In Google map always occure the
Always showing wrong direction. Having greater problem to explore new places.
Also please check the posting date also it showing 1970 instead 2019.
5 Comments
Minchu30
plz reset your phone
ANANDURPILLAI
how many time should I have to reset. I did it many time I need a permanent solution rather than adjustments.
Not applicable
use good lock gestures and for the hanging problem try disable the apps
m1991pokhriyal19
phon is hangging and slow work
m1991pokhriyal19
pls reply me
