Galaxy A35 Battery Drain Problem.in normal use not even playing any game
(Topic created on: Friday)
arpig
1. Please fix this problem.
2. Maximum user face this problem.
3. screen time only 2 to 3 hours.
4. Battery 🔋 drain mostly on social media normal use.
7 Comments
tapm
Right.please solve this problem. #A35
Ton-600
Yes please fix this problem 👏
Mazak421
Yes Solve this #samsung india
arpig
The problem is being experienced under Android 15 / One UI 7.0, which is often cited by users as the cause of post-update battery degradation. #samsung india
BiRdMaN
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
goodthings
goodthings
You're welcome to here.
