05-26-2025 10:30 PM (Last edited 05-26-2025 10:30 PM ) in
05-27-2025 01:20 PM in
Galaxy ADear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given link.
● Galaxy device vibration issue: https://www.samsung.com/in/support/mobile-devices/solutions-for-when-your-galaxy-phone-wont-vibrate-...
→ You can reset your device by following the steps.
07-20-2025 07:48 PM in
