Battery problem
(Topic created on: 02-22-2026 08:16 PM)
ishukatoch
My Samsung Galaxy A53 battery is draining very quickly. Although I got a new battery installed from Samsung's service center, I am still not getting good battery backup. We are getting only 3 to 3.5 hours of backup. And the idle battery charge is also very high. We have to charge the phone at least two or three times a day. So please listen to my request and help me if you can.
4 Comments
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
MdAliHossenKhan
Samsung A13
