Battery Problem!
(Topic created on: 10-11-2024 02:10 PM)
Problem99
Although I'm getting around 5-6 hours of Sot and the battery doesn't feel swollen too. Should I really be concerned about it?
3 Comments
MONOHAR12
What is this 😳
Arbaaz
You're battery health is weak.. That means it's capacity is around 50-75%.
cs_member10
Dear Samsung Member,
As per your query, you have shared the above screenshot regarding the battery health test and result showing weak then you have to visit the service center.
Moreover, kindly perform the following steps to resolve your Battery drain issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
Please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
