BATTERY DRAIN ISSUE GALAXY A13
(Topic created on: 11-21-2023 05:26 AM)
Ankuran
My phone phone #battery drain upto 14-17 % between 10pm - 6am. What should i do ? Plz suggest me 🙏
4 Comments
iadcy88
Turn off 5g at night
Sivadgokul
Turn off mobile data, location, hotspot,wifi, Bluetooth...use save battery at night routine from modes and routines option...you can also customize the routine according to your preference
Ankuran
I did everything but not satisfied
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps by a given link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue still occurs please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
