A51 battery drain and Low SOT
(Topic created on: 04-30-2021 09:04 AM)
lazypanda7
The battery drain on my phone is very high. I used to get at least 7 hours of Screen on time, but now I have used the screen on for 2.5 hours and my battery is 48%.
The phone is also using a lot.of battery on standby. It used 12%, battery just on standby, through the night, for no reason. The phone was on wifi only, no blutooth, no data.
The cameralightsensor has used 32.6% of battery! Why?
I am attaching the Screenshot.
17 Comments
MrHanamant
Even my device loose 5% by standby , no data on , no Bluetooth , nothing is on.
pran2002
Factory reset ur phone turn off always on display
MrHanamant
**bleep** for everything factory reset is not solution , please don't suggest that thing .
By the way I don't use always on display .
sfxut03
Factory reset and wipe cache pertition is the only solution
pran2002
If u don't do that off adpavtive brightness for always on display..for a series every senser is available on this phone so no draining issue for that kind of reason..or go তো service center
MrHanamant
For loosing battery life , if you suggest these thing why that feature in phone for?
It's about device optimisation and background services that are in use.
pran2002
**bleep** people think that..wipe catch is solution for many kind of problems and also factory reset..I also use a51 I have no draining in overnight and aslo 7.30 to 8.30 backup with mobile net
Not applicable
Turn off adaptive brightness and also clear data and cache of camera light sensor by searching on settings.
lazypanda7
I can't see the system apps, since the one ui 3 update :/. Do you know where to find it?
