12-10-2020 09:25 AM in
Galaxy ASolved! Go to Solution.
- Tags:
- galaxyA50
12-10-2020 10:43 AM in
Galaxy Aif you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
12-10-2020 09:28 AM in
Galaxy A- Mark as New
12-10-2020 09:29 AM in
Galaxy Aregister again with all sides of your fingers and add same finger 1-2 times for better result and lets see
12-10-2020 11:09 AM in
12-10-2020 11:50 AM (Last edited 12-10-2020 12:18 PM ) in
12-10-2020 01:33 PM in
12-10-2020 02:19 PM in
12-10-2020 02:33 PM in
A. Wifi scanning
A. Adaptive battery
