Resolved! Solved
A50 Fast Battery Draining Problem.
(Topic created on: 09-04-2020 04:00 PM)
Not applicable
Actually I'm facing too much fast battery draining issue in my A50 and also heating problems. Samsung badly ruined their A50 models in India and selfie camera also.Please Samsung fix the battery draining problem through the software updates it's a major & serious problem.🥺🥺
Plz guys let's request to Samsung to fix these issues because many users of Samsung's smartphones facing the problems regarding to the Fast Battery Draining Problem.
Resolved!
Ehsank
brother so many users , you are not one and only!
Ehsank
if you go through the post for next 1 week, then you can see how many users facing this issue.
Not applicable
Hey,man are in tech work
Not applicable
Appreciate ur help brother.
Ehsank
actually sometimes during update if our network not stable for a long time or some delayed in network reception then it would happen.
so if you have done all settings and it won't work then you have 2 option
first from your side is
reset/format your device with take proper backup
and observe for next 2-3 days
if solved then ok, most case it get solved but if unfortunately didn't work it too, then 2nd option is as i told you to visit service centre and get reinstall your software update
Not applicable
Actually I did all of above methods.
Ehsank
so don't worry it is not your handset issue
Not applicable
Thnx Brother
Ehsank
well come brother
Not applicable
