Resolved! Solved
A50 Fast Battery Draining Problem.
(Topic created on: 09-04-2020 04:00 PM)
Not applicable
Actually I'm facing too much fast battery draining issue in my A50 and also heating problems. Samsung badly ruined their A50 models in India and selfie camera also.Please Samsung fix the battery draining problem through the software updates it's a major & serious problem.🥺🥺
Plz guys let's request to Samsung to fix these issues because many users of Samsung's smartphones facing the problems regarding to the Fast Battery Draining Problem.
3 Solutions
Ehsank
and regarding heating issue do these settings once
Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
This will Help you if any 3rd party apps are causing heat.
Ehsank
so don't worry it is not your handset issue
ArkTech
use your phone with medium power saving mode all day and if possible so charge your phone normally without fast charging and charge your device on optimised mode only.....
charge your phone only 80% every day and 0 to 100 in a week !!!! restrict use battery in background for all apps....
good luck i hope its work for you 😊😊😊
and please accept my solution by tapping on 3 dots.
29 Comments
Ehsank
wait for update but as of now do these settings if you not done yet
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used and ON "GOOGLE APP" as well then click on>app info> then go to these 3 options below on by one
5. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
6. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder.
7. If you use Facebook frequently then disable "auto play video"
And if you are mostly uses mobile on wifi connection then also disable "auto play videos" in YouTube.
Ehsank
after these settings you will get a noticeable difference with in 2-3 days
Ehsank
and if my comments are useful and informative then you can accept as solution by CLICKING on 3DOT at my comments
Ehsank
Ehsank
and also you can wipe cache partition
Steps to perform.
A) Turn off the device.
B) Press and hold the Volume Up key and the spower button.
C) When the Android logo displays, release all keys.
D) Press the Volume down key to navigate and select "Wipe cache partition".
E) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
F) Press the Power key to restart the device.
This steps cleans Cache Partition which is stored in your device.
Samsung_PAMifqY
Beginner Level 3
This is not working as the phone reboots instead of navigating to cache partition to be wiped option
Not applicable
Is my phone battery damaged or is it a software problem? Plz tell me.
Ehsank
no battery problem brother
sometimes after software update it can happen
if after all done, still problem persists then visit service centre and get reinstall your software update
it will solve your issue
Not applicable
Do I have any other uses besides me that are having this problem?
