A20 battery Draining Problem
(Topic created on: 08-01-2019 09:21 PM)
RiazBd
Hello Guys... How are you all.
I need an solutions. I used A20. But nowadays i found a problem. When i cannot use phone, but battery charge drained automatically.
What is the solution...
Thanks in advance
4 Comments
DöRäEMöN
⚙turn off your always on display
⚙turn off your location when not in use
⚙turn off you wifi and Hotspot when not in use
if problem solved please give me accepted to give click on the three dots then click on accept solution
RiazBd
i tried everything, but does not working
shihab009
use this process and follow every order it suggest....
ajay_chopra
great post
