Shutter lag problem in S25 Ultra
(Topic created on: 05-26-2025 05:28 PM)
ankudhiman9
Delhi
In Samsung phones, I have seen a problem from the S22 Ultra to the S25 Ultra: shutter lag when capturing photos of moving objects. In comparison, iPhones capture tremendous photos of moving objects without shutter lag.
cs_member10
Delhi
Dear Samsung Member,
● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
