07-04-2025 09:15 AM in
DelhiDear Samsung Member,
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
07-05-2025 05:43 AM (Last edited 07-05-2025 05:44 AM ) in
DelhiIf this does not work send a error report through members through support menu.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved/Accept as a solution". Thank you 😊
