Wifi connection problem
(Topic created on: 04-13-2026 02:28 PM)
TilakAr
Community Guidelines
Wifi getting disconnected frequently in my s23ultra initially I thought my home wifi issue even in office multiple spots its getting like this
2 Comments
gopinaidu77
Disable wifi calling and change preferred network type to 4G for both sims. This will solve the wifi issue.
What is happening?
This is a MWS (Mobile Wireless Standard) WCI-2 coexistence bug in the Qualcomm Kiwi Wi-Fi firmware. Samsung should relase a new firmware and modem updates, no other solution.
cs_member10
Dear Samsung Member,
● Check Settings: Do you get any error pop up, on connecting your device to a Wi-Fi network?
Note: Any prompt that says "Authentication Error" is related to an incorrect password. Please contact your Internet Service Provider for assistance regarding changing your Wi-Fi network password.
● Forget the Network: Settings>Connections>Wi-Fi>Wi-Fi network> Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
● Reset Network Settings: Settings>General Management.>Reset>Reset Network Setting.
● Restart the Router and Mobile Device: → Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
→Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
→ Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
● Disable flight mode:→ Kindly check and disable the Airplane/Flight Mode on your device.
→Check Flight Mode by swiping down notification panel on your device with two fingers to access all of the Quick Settings.
→Find the Airplane/Flight mode option and turn it off.
