S 23 ultra battery drain
(Topic created on: 05-24-2025 01:45 PM)
Shon95
Beginner Level 4
Community Guidelines
Facing battery drain issue since the last ui 7 update. Any solution?
6 Comments
Please report your issue in detail using the Samsung Members app, and your concern will be addressed promptly.
Oldy4756
If it is just installed, then you should wait some days and if you can't wait, do a factory reset, as this is always recommend after a big OS update to settle it better.
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
Shon95
Beginner Level 4
Thank you
BiRdMaN
ShAMeSUNG will fix it in the next security patch update
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
