06-14-2025 04:21 PM in
Community Guidelines- Mark as New
06-14-2025 04:26 PM in
Community Guidelines2. Always on Dark mode.
3. Set performance profile to lite.
4. Clear background after using.
5. Turn off wifi, Data when no need.
6. Turn off Always on display.
7. Don't use live wallpaper.
06-14-2025 04:27 PM in
06-14-2025 04:29 PM in
06-14-2025 04:32 PM in
Community GuidelinesSettings > Battery > Battery usage
See which apps or services are using the most power.
Uninstall or limit apps with unusually high usage.
2. Enable Battery Saver Mode
Settings > Battery > Power saving mode
Enable this to limit background processes, reduce brightness, and disable Always-On Display.
3. Turn Off Always-On Display (AOD)
Settings > Lock screen > Always On Display
Disable or set it to "Tap to show."
4. Limit Background App Activity
Settings > Apps > [App] > Battery > Restricted
Use "Restricted" for apps that don’t need to run in the background.
5. Disable Unused Features
Turn off 5G, Bluetooth, Wi-Fi, NFC, or Location when not needed.
Use Airplane Mode in low-signal areas to prevent constant signal search.
06-14-2025 04:33 PM in
Community GuidelinesGreetings from scamsung...
As per your query regarding the battery draining issue, we appreciate your keeping interest in SCAMSUNG devices and services.
As per your query the battery backup isn't enough to you than we sugges to you buy scamsung's new device " S25"
And give us another chance to scame once again...
Thank you..🙏
Just joking bro
06-15-2025 11:41 AM in
06-17-2025 09:25 AM in
Community GuidelinesDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
