05-15-2025 09:04 AM in
Bengaluru- Mark as New
05-15-2025 09:45 AM in
05-15-2025 10:33 AM (Last edited 05-15-2025 10:37 AM ) in
BengaluruNow heating issue has been reduced, not much, but yes, I think so.
If your heating issue has been reduced too then please tell us.😊
05-15-2025 11:30 AM in
05-15-2025 11:53 AM in
Bengaluruhttps://r2.community.samsung.com/t5/Galaxy-F/Effective-Tips-to-Maximize-Battery-Life-on-Your-Samsung...
05-15-2025 04:24 PM in
BengaluruDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
05-15-2025 04:58 PM in
Bengaluru
