S20 fe 5g battery issue
(Topic created on: 04-01-2024 07:31 AM)
akvegi
Bengaluru
Hi, S20 fe 5g Yesterday onwards battery not charging more.than 74 percentage. Heating phone . And I diagonzed every thing normal. Is anyone facing ?
3 Comments
cs_member10
Bengaluru
Dear Samsung Member,
As per your query, we request you kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it at the earliest. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
akvegi
Bengaluru
Sure thanks
Bengaluru
I have s20Fe and apparently it is running smoothly 🤞🏻
