Tips for using Galaxy Fit and Fit-e on your Galaxy Smartphone
(Topic created on: 07-17-2020 02:53 PM)
karansingh005
Wearables
Samsung provides two entry level Fitness bands, Galaxy Fit and Galaxy Fit-e. Both are pretty good devices, but you require some tips to get the best out of them. In this post, we are going to explore some of the ways, that we can get best out of our Galaxy Fit and Galaxy Fit-e!
Installing essential applications
To get the best use of Galaxy Fit bands, we need to install two applications, which generally come pre-installed on your Galaxy smartphone. Those are:
1. Galaxy Wearables : This provides various settings and functionality to your Galaxy fit. This application is a must to use your Galaxy fit as it provides ability to update Software updates on your Galaxy Fit and other essential things.
2. Samsung Health: This app provides lot of functionality in terms of giving visual representation of your health data, measured by your Galaxy Fit. The app itself works pretty well for steps count and other exercises, even without Galaxy Fit.
Changing Watchfaces
1. Go to Galaxy Wearables application.
2. From bottom, click on watch faces. There are 20 watch faces available to choose from.
Heart rate recording
To enable constant heart rate recording:
2. Go to health settings of your Galaxy Fit.
3. Enable auto heart rate. You can choose the time period of recording the heart rate. You may choose from 10 minutes to constant heart rate recording.
Heart Rate data and Charts
1. Go to Samsung Health.
2. Click on heart rate. Here you can check trends of your heart rate, and application provides charts of trends of your heart rate.
Automatic Exercise Recording
3. Enable auto detect exercises. This will automatically detect exercises, whenever you're active for more than 10 minutes. These recorded exercises can be viewed in Samsung Health.
Adding more Widgets on your Band
1. Go to Galaxy Wearables.
2. Click on widgets, and add more widgets to use on your Galaxy Fit.
Enabling Double-Tap to wake
2. Go to Advanced, and click on Screen wake up.
3. Click on Double tap to wake up.
To manage Notifications of your Galaxy Fit
2. Click on Notifications. Here you can enable or block notifications from certain applications, onto your Galaxy Fit band.
To check for Software Update of your Galaxy Fit
2. Click on Update Band Software.
3. Click on Download and Install.
To change brightness and screen timeout of your Galaxy Fit
2. Click on Display.
3. Here you can change screentimeout of your Galaxy Fit and brightness as well.
Hope this post helped you. If you want something else to be included as well, do comment down in comments below!
