How to pair Samsung Galaxy S21 ultra to Samsung Gear 360?
(Topic created on: 09-10-2021 02:05 AM)
Domrany
Wearables
Please don't send me the obvious methods like:
https://publish.samsungsimulator.com/simulator/01789598-0a0e-4a05-9b3a-2259745e02fe/
The problem is, there is no "Samsung Gear 360" app, anymore!
Instead, the app that comes up is "Galaxy Wearable" which I'm using for my "Galaxy Buds Live" and "Galaxy Gear S3" smartwatch.
To add the Gear 360 to this app:
Hamburger menu =>> Add new device =>> turn on the Gear 360 =>> long press on the menu button =>> press on record button when "Connect to Android" is on it's scree =>> Locate and select "Gear 360 3FB0" on the app =>> accept the pairing key showed on my phone screen =>> and error happens
After the key it says your watch(!) is paired, my actual watch gets disconnected, then the app says "Unable to install, Unexpected error" with two buttons: "Close app" and "Contact us"
If you want to suggest removing the other paired devices including my smartwatch then try again, I have done that already! That's a dead-end, too!
My phone is Galaxy s21 Ultra 5G running Android 11. My Gear 360 is SM-R210
Any solution that actually works?
5 Comments
VinodGowda
Wearables
Open Bluetooth option it's showing the instructions clipboard_image_1631243354793_1631243354793.jpg
Domrany
Wearables
This is not instruction that is useful to my case!
But there is a line that is beneficial
"The Galaxy Wearable application does not support the Gear VR or Gear 360"
The question is, what app does?
ndantas
Wearables
Whenever I try this steps I receive a error message: An unexpected error occurred. Close / Contact Us
Papihavana
Beginner Level 3
Wearables
To: Samsung!!!
Please update Gear 360 App or add it to your your wearable app. I paid $279 for my camera and only used it on a few occasions. Now it's almost like a paperweight that isn't that heavy.
Lugway
Wearables
Dowload the APK gear 360 with Aptoid ans it works
