Galaxy watch 4 classic LTE battery drain after update
(Topic created on: 03-09-2025 10:08 PM)
KunteAmith
Wearables
Hello there,
I just received a new wear OS update for my Galaxy watch 4 classic LTE. And my watch battery is draining 1% every 60sec or so, watch has become laggy, watch face takes forever to complete launch.
P.S I'm bot using LTE plan on my watch.
Why has samsung become so lazy to test there update package throughly before launching it as a stable build to public.
#wearOS 5.0 #OneUI watch 6.0
14 Comments
Tushar1406
Wearables
I am also facing same issue
Rasik007
Wearables
Bro its working absolutely fine with me. No issues at all.😮
KunteAmith
Wearables
Good thing for you then..... how old is your watch..??
Rasik007
Wearables
1 and half yr
KunteAmith
Wearables
Mine I bought with my s22ultra during luanch
Rasik007
Wearables
Ok.
Record4
Wearables
If you use LTE mode, battery drain fast. Use LTE mode when necessary.
KunteAmith
Wearables
I'm not using LTE mode, I have removed that service as when I have received a call in lte it used to get hot soon and go to cool down mode. So I have remove LTE plan ages ago
cs_member8
Wearables
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve the battery-draining issue.
There are several reasons why your Galaxy Watch may be experiencing battery drain or have decreased battery life.
For example, certain apps can increase battery consumption.
● Inspect the watch and charger for physical or liquid damage.
● Use only Samsung-approved chargers and accessories, which are specifically designed for the device. The Watch cannot be charged properly with a third-party charger.
Follow the given tips to resolve the battery draining issue:
1: Perform a diagnostic- If your watch is paired with a Samsung phone, you can use Samsung Members to perform a diagnostic on your watch battery. If it passes the test, you'll know the battery is in good condition.
2: Update your apps: Sometimes apps may have a bug that causes them to use excessive battery, make sure all your apps are up to date for the best performance.
3: Update your software.
● From your phone: Galaxy Wearable app > Watch settings or SETTINGS > About watch > Update watch software Or tap About Gear > and then tap Update Gear software.
● Tap Update now or Download updates manually, and then follow the on-screen instructions. If desired, you can choose to automatically update the software by turning on Auto update or Download updates automatically. The watch will disconnect during this time.
● After checking for software updates to your watch, check if any updates are available for apps installed on your watch.
4: Turn off unused health trackers.
Sleep: Tap Settings at the bottom of the menu, turn the switch off, and then tap OK to confirm.
Heart rate: Tap Auto HR Settings from the bottom of the menu, and then tap Never.
Stress: Tap Auto stress settings from the bottom of the menu, and then turn the switch off.
5: Delete data and close background apps.
Note: These steps do not apply to the Galaxy Fit.
From your phone: Galaxy Wearable app > Watch settings or the SETTINGS tab > About watch or About Gear > Storage > CLEAN NOW, > tap the Back (<) icon > RAM > CLEAN NOW.
6: Turn off network connections.
7: Turn off Watch always on.
8: Turn off voice wake-up in Bixby or Google Assistant.
9: Customize your notification settings: From your phone- Galaxy Wearable app >Watch settings or the SETTINGS tab > Notifications > Advanced notification settings > switches > Show with details and Turn on screen.
10: Turn on power saving mode: Press the Home key (Power key) on your watch, > Settings > Battery and device care > Battery or Battery management > switch next to Power saving.
11: Do not expose your watch to temperature extremes: Exposing your watch to very cold or very hot temperatures can shorten the watch's battery life and could lead to damage.
In case the issue still occurs, please share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application(Wearable app>Three dots>Settings>Contact Us> Send feedback>Choose Composer> Select error report > select the appropriate issue category> Type your query and send.)
