Galaxy Watch 6 classic LTE mediocre battery life
(Topic created on: 08-20-2023 02:30 PM)
arunnechlani
Wearables
Hello Galaxy Watch 6 classic LTE owners,
How much battery life you are getting on your GW6 Classic LTE?
I am getting extremely pathetic battery life, did reset but useless. I start using morning 8 am and but night 10 pm it will be around 11%.
Always on display, LTE configured but Samsung claims 30 hrs for such settings.
11 Comments
Aashish
Expert Level 4
Wearables
It will get better in a while.
cs_member8
Wearables
Dear Samsung Member,
We acknowledge your query. We request you kindly visit the service center for a physical inspection of your device. So that they can check the exact issue with the device and fix it as the earliest. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
NOMAĐ
Wearables
Is this a template?? Atleast understand the query before answering.
bhavin123
Wearables
Same problem
Have charge my watch 6 classic lte 100 % at 10 am by midnight 12 it was around 20%
AOD is off
arunnechlani
Wearables
Hmm than it's more of software optimization problem. I turned off LTE to see how it behaves and no overnight drain at all.
NOMAĐ
Wearables
Turning on LTE should drain more battery. Had the same problem with Watch5.
Battery time is less when comparing watch6 with watch5. A software optimization might bring better battery.
arunnechlani
Wearables
Just for testing purpose I tried turning off LTE, then 2 1/2days came without AOD
bhavin123
Wearables
Switching off LTE for better battery life it's not a solution we have paid extra for LTE version in that switch off doesn't make sense
arunnechlani
Wearables
That's true, was just trying how does it perform. Optimization is needed in LTE for sure
