Resolved! Solved
Audio 360 problem
(Topic created on: 04-08-2022 04:35 PM)
Tommy_Jcb
Wearables
Hello i have a problem , i make the Update to get the audio 360 on my galaxy a71 for my galaxy earbuds 2 . And when i go on the app i didn't see the option anywhere . At least my device is at 3.1 Ui and Android 11  . I make some search on internet and didn't found nothing.  Pls help me thanks
DjCraigQ
Wearables
I think this option is only available for the buds pro and not buds 2. I have both earphones.
3 Comments
Tsogo_sam05
Wearables
Hi Tommy_Jcb, kindly access Galaxy Wearable app > Menu > select device list > Earbuds settings > 360 Audio > enable ‘360 Audio’
Tommy_Jcb
Wearables
I do not have this option , i dont know whyScreenshot_20220409-145411_Galaxy Buds2.jpg
DjCraigQ
Wearables
