what is speed difference for 6gb and 8gb ram?
(Topic created on: 03-19-2021 03:10 PM)
TechDeva
Tech Talk
Any idea.
6 Comments
Tech Talk
peculiar question..🤣 because it's also depends on which type of app you are using, which company phone you are using, what are the apps running on backwards,how much app installed in device etc
AbhishekPuri
Tech Talk
6GB RAM smartphones will work as fast as an 8GB RAM smartphone if they are paired with a strong processor. Additionally, most users cannot even differentiate between the speed and performance level of a 6GB RAM and 8GB RAM smartphone. . Apps Are Designed For Lesser RAM
and there is only different between storage or nothing. in 6gb ram device same as 8gb device there only different of storage where u store more 2gb file (like apk and in future you use your device as long time)
Ehsank
Tech Talk
no huge speed difference little bit good performance you may get
Tech Talk
Not a major difference..and speed of your device depends on many factors,but in general very minor difference
sum834
Tech Talk
ram speeds does not usually depend on the size. 6gb ram gives you the same speed as 8gb ram is they are of same generation. So in ram the speed depend on the generation. In smartphones generally the speed is due to its processor so better the processor more is the speed. Ram size on matters if you do many works at same time or use very large applications.
TechDeva
Tech Talk
good to see
