solution of battery drain problem in any galaxy mobile .
(Topic created on: 05-31-2021 03:30 PM)
prashantanp955
Tech Talk
All of you , Please read my advice once. For solving battery draining, hanging and background app running problem.
 Follow the step below .
 1. Go to setting
 2. Click device care and battery setting
 3.Open Battery
 4. Turn on power saving mode
 5. Put app to sleep mode
 6. Rearly used app put in deep sleeping mode.
 7. Go to developer process in setting and turn off background data usage limit. How to open developer mode
 a. Go to setting of your mobile
 b. Go to about phone
 c. go to software information
 d. Click 7/8 times your mobile build number then devoloper process unlock in your mobile .
 After done all your problem being solved . Sure .
 Believe me and accept solution .
5 Comments
Msngalaxy
Tech Talk
Where is Background data usage limit and how to set this?
Tech Talk
Please read full my status . You get solution sir
ashraf1995
Tech Talk
Haaa
Tech Talk
it is best solution sir.
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
