otg and usb tethering problem
(Topic created on: 12-21-2019 11:39 AM)
Not applicable
Tech Talk
my device is galaxy j6. problem in otg connect and USB tethering..when connect my pc only charging not connect via USB tethering and otg.
13 Comments
Tech Talk
When u r connecting to PC it should ask you "Allow access data". please select "Allow". There will be a pop up in your computer screen, there you can select Open device to view files. You can use it. For OTG there is no other setting. u can connect and start using. if it is still not working then try that pendrive in any other phone compatible for OTG. if it works there then it should work here. still if it is not working then get the port checked at service center. they will help you.
Not applicable
Tech Talk
no working.. jack problem bhi ho sakti h kya?
Tech Talk
haan jack ka bhi hosakta hai. 1 baar service center me check karwalo. it's under warranty I think. waise jack ka issue hota hai to charging me problem hota hai but 1 baar check kara lo thik hojayega.
Tech Talk
A30 galaxy usb problem
Tech Talk
what prblm
DINESHGARG
Tech Talk
hello
manoj5279
Tech Talk
hey hii
manoj5279
Tech Talk
I'm trying to connect my USB pen drive but it was not connecting
hasmat
Tech Talk
my divice is not working usb otg
