note 9 having display problems
(Topic created on: 04-21-2020 02:32 PM)
vassipra
Tech Talk
I'm  using note 9 ...After march update phone got display brightness problem...Also colour fading with some lines visible....
Any solution for this problem
7 Comments
Not applicable
Tech Talk
we can just report to Samsung.
vassipra
Tech Talk
so many of customer having this problem
Mani18
Tech Talk
yes it's the Sam issue for S9 Plus as well
NITHINJAMI
Tech Talk
better if you do some INTERACTIVE CHECKS in the device using Samsung members application
vassipra
Tech Talk
ok ... thank you sir
Samsung_Support4
Tech Talk
Dear Samsung Member,
Please perform the below mentioned step to resolve the issue:
1. Check device in Safe Mode.
1. Press and hold the Power key, when Power off icon appears.
2. Press and hold the power off icon.
To exit safe mode just restart your device.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > click on “+“icon > send feedback > error report/ask questions).
vassipra
Tech Talk
thanks for your kind support....i will do as per your suggestion...
