mobile heat problem and battery drain a50 please guays solution
(Topic created on: 01-15-2020 01:51 AM)
Sonukkr
Tech Talk
Samsung Galaxy A50
5 Comments
Ellies
Tech Talk
Try close background apps also mobile data
and after all it depends on your use
Tewatia
Tech Talk
Factory reset your mobile
Tech Talk
and performance had degrade
GSR9727
Tech Talk
First of all,run ur device in safe mode.to enable safe mode restart ur device using side button then while restarting when Samsung logo appears then press volume down button.if ir issue gets resolved then it is bcoz of some apps.try uninstalling them.
If Not---then:
Try reset app preferences in apps from settings and then reset settings from general management.(this will not cause any data loss).Then from device care-battery-put app to sleep-whichever app u want put them to sleep.this will definitely help u increase ur battery life and performance.
IF THIS ALSO NOT WORKS
then follow Standrad charging procedure---in this
u have to fully discharge ur battery and u have to charge it for 150 minutes in switch off mode.
THE ABOVE STEPS WILL DEFINITELY HELP YOU.
if all the above doesnt seem to work then show ur mobile in a Samsung service centre.you can get details of nearest service centre in Samsung online chat
Samsung_Support1
Tech Talk
Hi there,
Please perform the following steps to resolve above mentioned issues:
For battery drainage issue follow the given link- http://www.samsung.com/in/support/skp/faq/1101689
For heating issue follow the given link- http://www.samsung.com/in/support/skp/faq/1119803
For further assistance, register your concern in Samsung members application (Open Samsung members app > click on “+“icon > send feedback > error report/ask question).
Regards,
Team Samsung Members
