hello friends how do I turn off camera shutter click sound
(Topic created on: 08-31-2020 06:30 PM)
rinnavsidhu
Tech Talk
9 Comments
Tech Talk
There is no official way to turn off camera shutter sound..only possible option is to mute device sound while taking photographs
or
if your device supports bixby routines then use that to turn off camera shutter sound
Ehsank
Tech Talk
only one way, silent your mobile
veer
Tech Talk
right
rinnavsidhu
Tech Talk
why do they keep a option like this..I feel my old mobile vivo had better options
rinnavsidhu
Tech Talk
anyway thanks friends
Tech Talk
If you are satisfied with response then click at 3 dots near my 1st comment and accept it as solution to help others..
Also, its due to some EU laws..
Not applicable
Tech Talk
only you can do if your device supports Bixby routine....otherwise mute your device to operate that action
SrajTech
Tech Talk
you can't disable it.
just put your phone on vibration mode or mute, no sound will be heard.
Kawsar4s
Tech Talk
go to camera setting then turn of shutter click
