battery issue
(Topic created on: 10-02-2020 11:02 PM)
pramaniksubo
Tech Talk
after update my galaxy m31 update my phone battery draining very fast kindly solve this problem.
9 Comments
Siva4
Tech Talk
Turn on the Safe mode
Tikunwengsu
Tech Talk
backup your device & factory reset maybe might solve your problem
Amandeep
Tech Talk
do a factory reset
Ehsank
Tech Talk
if after update then you can do 2 things and lets see
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
Ehsank
Tech Talk
besides above i would like to suggest you to do these settings to save more battery life and observe for next 1-2 days
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, INSTA,YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
6. If you use Facebook frequently then disable "auto play video"
Ehsank
Tech Talk
and if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comments
Not applicable
Tech Talk
mobile data or wifi se software update kia kya ? smart switch ka use karo which is process
UsEer
Tech Talk
how much screenon time are you getting ?
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
