battery issue
(Topic created on: 06-22-2020 02:52 PM)
INB2dec
Tech Talk
Hi,
   Just few days ago I have purchased samsung galaxy m31 ,6 gb ram and 128  gb rom.I choose this for the battery,but using this feeling same as other mobile battery.Even I feel my 2 years old motorola's battery is better.It is draining quickly.If I watch video song in youtube then every 7 or 8 min 1% is decreasing.Is that normal for this battery?I have gone through most of the feedback from forams and have adjusted the settings,such as stopped background data usage or application use etc.Is my battery ok or I got a damaged mobile?Kindly let me know in brief what to do.
4 Comments
beniatgalaxy
Tech Talk
same problem with my galaxy m21 . it gives battery kife of 3500 to 4000 mah even though it has battery of 6000 mah
Tech Talk
same bro with SamsungGalaxy m21
Tech Talk
Let me provide you some troubleshooting steps so you can diagnose your problem yourself instead of visiting to the service center.        Step (1):Perform Battery Optimisation. Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory.                                  Step(2):Turn off Bluetooth, Wi-Fi, mobile hotspot, NFC, etc a). Swipe down on the home screen to open the notification panel. b). Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.      Step (3):Kindly check whether the mobile network fluctuates frequently or network signal is low in your area. In both cases, the battery will drain considerably fast. Step(4):Reduce display brightness level. a). Swipe down on the home screen to open the notification panel. b). Turn on the Auto-brightness option if available. Step(5):Adjust screen timeout settings. Go to Settings > Display > Screen timeout > minimum screen timeout.      Step(6):Update apps. Kindly check which application is or interface is using more battery from device care. And try to update the app or avoid using that app.               Step (7):Close background running apps. Tap on recent key and close the background running application.                        Step(8):Turn off auto-sync of e-mails, app data, etc. a). Swipe down on the home screen to open the notification panel. b). Turn off the auto-sync option. Step(9):Check device in safe mode: Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key. Exit safe mode: Restart the device.        Step(10): Try your device in safe mode.           As you were facing battery drainage issue in your device, I have provided you some basic trouble shooting steps and your concern has been resolved.                          "If the problem is solved click the three dots & click solution".
Samsung_Support3
Tech Talk
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
