WIFI problem
(Topic created on: 08-30-2020 06:57 PM)
Amit0007
Tech Talk
Wifi of M21 not detected from Lenovo G50 laptop, but other phone like LG , Honour all are detected by m21 and my Laptop both, please solve.
Please note if I connect with Bluetooth and USB with laptop mobile hotspot working and giving internet to laptop.
8 Comments
Not applicable
Tech Talk
this is a strange problem,sorry I can't help.
Ehsank
Tech Talk
try these one by one
1. Forget all WIFI devices which were connected earlier.
Again turn on WIFI> Scan> and try to connect.
2. Or click on "add network "and try to add manually.
If after all settings if won't work then
 3. Reset network settings (Scroll down notification panel >Settings>General Management>Reset >Reset network settings)
If even after above settings not resolved then do below option to check
 4. Perform Interactive checks through Samsung Members app (Samsung Member> Get Help> Interactive checks>WIFI).
Anonymuos
Tech Talk
Try updating the network driver of your PC/ Laptop. Control panel> Hardware and sound> Device manager > Network adapters - here you will get the name of the specific network adapter in your computer. Search for network adapter drivers for your Windows version and manufacturer (hp , Lenovo etc.). Download and install the latest driver available.
Amit0007
Tech Talk
As instructed , all the action done, but problem still over there.
Ehsank
Tech Talk
did you try to add manually
Amit0007
Tech Talk
Everything has
done but problem not solved
RjKingRj
Tech Talk
wait for next update
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
To resolve Wi-Fi issue kindly follow below given step:-
- Forget the Network:-
Go to apps screen > Settings > Connections > Wi-Fi > Wi-Fi network > Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question), along with the screenshot and videos.
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
Thank you for contacting Samsung.
