Technical help required
(Topic created on: 03-22-2024 02:26 PM)
DRDHRUVIL
Tech Talk
Good afternoon everyone ,
Fews days back i took temporary back up to samsung id
Now everything restore without getting problem but my secure folder is not getting be a restore .
It's asking password which password do i need to put in there previous one or accounts password
I tried both but nothing is working &also there no option of reset password .
I'm attaching the screen shot please help me out with it
9 Comments
sokiotali26
Tech Talk
Jwje
DRDHRUVIL
Tech Talk
Mayur000
Tech Talk
Not possible, the secure folder will not work now...
You have to reset the device, but for that just logout from all browsers, facebook, youtube, google, etc.
Remove password, pin or pattern lock and then remove all user accounts from settings - users
Then reset the device..
Install all apps again.
Reason: Backup and restore not work in a secure folder
DRDHRUVIL
Tech Talk
Already tried bro
Mayur000
Tech Talk
Always prefer passwords less backup..., move your files out to secure folder then remove secure folder then use backup and restore.
Tech Talk
Try your phone's old password once.
DRDHRUVIL
Tech Talk
Already try everything
techki
Tech Talk
When you took backup, it also asked to create password, that's the password you have enter.
DRDHRUVIL
Tech Talk
Its not working
