Sound level control on notification panel??πŸ€”πŸ€”πŸ€”
(Topic created on: 01-03-2021 02:34 PM)
Not applicable
Tech Talk
SOUND LEVEL CONTROL ON NOTIFICATION PANEL(just like brightness control)  PLEASE πŸ™πŸ™πŸ™πŸ™
9 Comments
Γ‚Ε
Tech Talk
You can try this
Not applicable
Tech Talk
still! it's not the same? I want it to be just like brightness bar for reliability, don't u think it would be better that way?
Not applicable
Tech Talk
then use assistant menu by accessibility settings
Not applicable
Tech Talk
i don't want that floating acc. menu. button while surfing
Not applicable
Tech Talk
floating? which android version you have ? now assistant menu can set to edge screen...check settings .... otherwise if your version is 2.0 then long press on assistant menu icon and drag it to notification panel
dj9494
β˜…β˜…
Tech Talk
kindly share this in the feedback section of this app πŸ™
dj9494
β˜…β˜…
Tech Talk
really a good feedback
Sidhabhi
β˜…β˜…
Tech Talk
lucdreams
Tech Talk
you literally have physical buttons for volume control why do you need volume controls in the notification panel
