Solving toh problem of auto reboot samsung a21s
(Topic created on: 01-30-2022 06:51 PM)
rameshwarmtrsn
Tech Talk
dear sir,
 Facing the reboot problem of samsung a21s automatically this problem,how to solve it
And for this problem you will give new version software after fixing these all types of bags and provide more stability in the software.
6 Comments
cs-member13
Expert Level 4
Tech Talk
Dear Samsung member,
Kindly use a genuine Samsung charger.
Note: We always recommend using a genuine Samsung charger for charging your device.
There are two methods to disable the auto-restart function
Method 1
Please follow the below steps:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on General management.
Step3: Tap on Reset.
Step4: Disable Auto restart (if enabled).
Step5: Auto-restart disabled.
Step1: Go to "Settings"
Step2: Tap on "Battery and device care"
Step3: Tap on Three dots
Step4: Tap on "Automation"
Step5: Disable "Auto-restart at set times" if enabled
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback >Error report).
Warm regard,
Tech Talk
Hanging problem sir
After seen recent trey it becomes reboot
Tech Talk
Dear sir
This is not my phone problems
Tech Talk
My problem is hanging
After hanging it becomes reboot and take 10 to 15 minut for restart.
Please 🙏 sir provide new update for my phone.
sparshi
Tech Talk
My problem is still occours all setting are disible of auto restart but it still it is restar itself
Tech Talk
Ye problem june tak sahi hogi
