Solution, video audio stuckd problm while using wireless headset after 12 update
(Topic created on: 01-21-2022 10:45 PM)
Aslamshaz
Tech Talk
connect wireless headset and just go to settings.then sound and vibration.scroll down .click on separate app sound.press turn on now.Then select, app option and click add apps.then select a app which is not a media player or social media app. the app that doesnt need speaker or mic to work.photo editor app is best choice.Then finally select audio device us bluetooth .thats all.
or
Settings...developer option(can be enabled by.. about phone....software information....build number click upto 5 times) select bluetooth audio codec and change aptx to sbc. all done
cs-member13
Expert Level 4
Tech Talk
Dear Samsung Member,
Thank you for sharing your feedback. We appreciate the time and effort you have spent to share your valuable comments. This will help us to improve our services.
