Resolved! Solved
Samsung M31 Audio Problem
(Topic created on: 07-15-2020 06:03 PM)
RyZo
Tech Talk
I just got my phone like 2 days ago. I havent faced any problems or anything (except this). So, if I'm on a call with someone or I'm using Zoom or Google Meet, all the audio coming from the phone sound terrible. like YouTube or Spotify sound really bad.
I have really good internet and I've tried this with and without headphones. Sometimes the call itself sounds bad and sometimes the call is fine.
PLEASE FIND A FIX.
Resolved!
RyZo
Tech Talk
okay I'll try and update this if it's fixed
RyZo
Tech Talk
tysm it worked even after I turned off safe mode
does this mean some app is interfering?
Tech Talk
Yup, this means that some app is making your sound experience bad.
You have to find one after which this all started.
RyZo
Tech Talk
okay.. but how do I find which one it is?
AgentDarkFury
Tech Talk
Issue continues for me
I bet it's the problem with that Android 11 update.
It worked perfect before the update
Diablo2212
Tech Talk
if you don't mind me asking did you get updates after April patch ?
RyZo
Tech Talk
I got an update yesterday for what I think was the android 10 mashup so I installed it
I didn't face the freezing thing problem
Tech Talk
ok
Diablo2212
Tech Talk
hello is there any update for m31 after April patch update ?
naveenaaron
Tech Talk
bro pls return and get new one
