S7 edge voice network operator problem
(Topic created on: 12-28-2019 12:17 PM)
srigee
Tech Talk
My mobile not hearing and mix not well. But music and chrome voice are cleared. I think it was happened after updates the software on dec 18. I am looking support
Tech Talk
Hi there,
We would suggest you to follow the mentioned steps to resolve the issue:
1) Ensure that network frequency of your device is selected on Auto-mode.
Settings > Connections >More Networks > Mobile Networks > Network Mode > Select Auto mode (GSM/WCDMA/LTE)
2) Search for the Network Manually by the steps as mentioned:
Settings > Connections > More Networks > Mobile Networks > Network Operators > Select Manual Search.
3) Check via other SIM card in the device and also try using different network operators.
4) Reset network settings (Scroll down notification panel >Settings >General Management >Reset >Reset network settings).
5)Perform Interactive checks through Samsung Members app (Samsung Member> Get Help> Interactive checks->speaker).
If still issue persists then we would suggest you to contact your service provider.
Regards,
Team Samsung Members
