Power saving mode drains more battery
(Topic created on: 05-24-2021 10:04 AM)
OptimusPrime108
Tech Talk
Yesterday night I had 27% battery left. So, I turned on power saving mode with limited apps and home screen. When I woke up in the morning after almost 7 hours, I saw the battery was at 10%.
 This is not the case normally. When I keep the 'limit apps and homescreen' off, it drains around 5% overnight. Is this a bug??
Update #1: someone suggested to turn off adaptive battery. I did. Now it has drained 10% (57 to 47) overnight for about 7.5 hours.
18 Comments
Tech Talk
See, you have turned on both power saving and adaptive battery. I think these to battery savers are crashing and causing the battery drain.
So this night kindly try turning off one of the options it can work
If u find this helpful kindly click on the three dots and click accept as solution
Shaurya7
Tech Talk
Ya it's not a bug it's actually a clash between the power saver mode and adaptive battery.
If u turn on both adaptive battery and power saver mode it will drain more battery at night in standby mode.
Try to disable adaptive battery in night during standby, it will consume less battery.
Tech Talk
Ok. Will test it out today night. Will update my findings here.
Tech Talk
I did turn off adaptive battery. Not a huge improvement though. Over 7.5 hours, the battery drained 10%.
Not applicable
Tech Talk
Turn on airplane mode and your phone will drain 0-2%. Just try it!
Tech Talk
I can't. It is my work phone.
Aditya127s
Tech Talk
Battery saver se aur battery draining hota hai eslia bina battery saver ke hi thik hai
Blackwinter
Tech Talk
Help me I am also facing same issue in my a50s. Overnight battery drain is around 18% .
See my latest post.
Tech Talk
Put all useless apps to deep sleep. Don't turn on adaptive battery if you have turned on adaptive power saving.
